Topic Messages
Zetorworld forum
Tractor forum
gearbox
Moderators: Renze, TomZ
The Web Zetorworld.com only
rover
gearbox
  Started at Sat Mar 9 16:57:55 2013
Would anyone know if a 6711 gearbox fits a 6011
Renze
Administrator
Member Icon
Goed goan !!
Gender:
Re: gearbox
  Reply #1 Posted at Sat Mar 9 17:25:36 2013
Last Modified at Sat Mar 9 17:27:15 2013 by Renze
I had trouble fitting the 5245 loader to the 5718, the difference between mounting points was more than the 12cm with of the cylinder heads. This leads me to believe that the 6011 and later rear ends were 2 cm longer... ?? But im not sure.
Anyways, it will bolt right up, and you can put the gearlever on that transmission too. But you might have to modify the cab mounts a wee bit.
4911 Bjarne
Member Icon
Gender:
Re: gearbox
  Reply #2 Posted at Sun Mar 10 12:11:13 2013
On the 7,9 and 10 series the geareboxcasting have the same partnumber, on the 12 serie there is anoter partnumber.
I have not compered all the shafts but it is plousible thay are the same. You can download partsbook for both traktors from : http://www.maskinisten.net to compere.
Bjarne
Renze
Administrator
Member Icon
Goed goan !!
Gender:
Re: gearbox
  Reply #3 Posted at Sun Mar 10 21:32:20 2013
Our 5245 had a gearbox with casting number 6011...... so i assumed that they would have been in production from the 10 series onwards. But it doesnt allways mean that.
rover
Re: gearbox
  Reply #4 Posted at Mon Mar 11 20:39:49 2013
Tks for the Info, will let ye know how I make out
Member List Member List
Who's online: Lousekt, raaausatpeiy, 22 guests
