Topic Messages
Zetorworld forum
Tractor forum
Stuck shifter and four wheel
Moderators: Renze, TomZ
The Web Zetorworld.com only
Rjackson
  Started at Wed May 25 02:33:52 2016
I am not very good with computers and I tried to answer the guys that replied to my question and looks like I just replied to my own message so I have to post again. Renz said I was to put it in 5th, speed up and drop the clutch and brake at same time. I know I am really dumb, but does drop the clutch mean depress it or let it out? I tried what I thought was correct but did not work. Four wheel shifter is also stuck, it is up but I do not know if that is in four wheel or two wheel. Mike said to back up.
Is it okay to disc in high range? Some have said not to, I will burn something out.
This is a first for me, I am used to gasoline tractors. Any help would be greatly appreciated. I was hoping there may be some linkage adjustment I could do
Renze
Administrator
Member Icon
Goed goan !!
Gender:
Re: Stuck shifter and four wheel
  Reply #1 Posted at Wed May 25 20:34:36 2016
Last Modified at Wed May 25 20:41:36 2016 by Renze
Yes, speed up and push brake and clutch pedal at the same time whilst shifting the range or 4wd. To get enough speed to lock the rear wheels when braking, you need to be in 5th when in low range. It will un wind the 4wd driveline.
Discing is generally done in 3rd gear high range. Both ranges can take full engine power, it is not like a 4wd pickup.
I used low range only to deep cultivate in 5th low, because it is just between 1st and 2nd of high range.
Be sure to disengage 4wd on hard surfaces or it will eat its front tires.
forterra11441
Member Icon
Nothing runs like a Zetor
Gender:
Re: Re: Stuck shifter and four wheel
  Reply #2 Posted at Wed May 25 20:45:25 2016
On Wed May 25 20:34:36 2016, Renze wrote: (read quoted post)
its almost impossible to shift hi low range when 4wd is engaged for these tractors, twist the 4wd lever and pull it up and lock it by twisting it forward, you should have the feeling of stretching a spring when pulling it up. then drive the tractor and slam hard on the brakes dont use the clutch just slam on the brakes going forward. it will pop out of 4wd by the help of a spring in the lever. then you should be able to shift the hi low range easily. this procedure is what i do with my 6340 when this happens. if you have a loader it also helps lifting the front wheels of the ground to get the 4wd to disengage.
Happy owner of a 2013 Forterra HSX 140, with track lift 260 SLi loader, 1994 6340 with Quike 640 loader.
Rjackson
  Reply #3 Posted at Thu May 26 02:41:31 2016
Oh thanks! I got it out of four wheel, still can not get it out of high range, but, if it's okay to disc and bush hog in high, just going to not worry about it..can not thank you enough!!
forterra11441
Member Icon
Gender:
  Reply #4 Posted at Thu May 26 19:58:46 2016
put it in gear 1 or 2 and try rocking it in reverse while you try to shift.
Renze
Administrator
Member Icon
Goed goan !!
Gender:
  Reply #5 Posted at Fri May 27 03:45:59 2016
Maybe it needs some WD40 too, on the lever shaft
Member List Member List
Who's online: 26 guests
