Topic Messages
Zetorworld forum
Tractor forum
Valve adjustment sequence-5711?
Moderators: Renze, TomZ
The Web Zetorworld.com only
SiH
  Started at Sun Sep 10 19:48:15 2006
Just about to adjust the valves on my 5711 as they were all tight before I worked on the heads.
Could anyone tell me the correct sequence in which I should adjust them please?
Many thanks.
Hi all! from a Brit in France.
Alzet
Member Icon
The happy driver
Gender:
Re: Valve adjustment sequence-5711?
  Reply #1 Posted at Mon Sep 11 07:10:38 2006
Use this method.
Adjust valves 1 & 2 with 7 & 8 on the rock.
Adjust valves 3 & 4 with 5 & 6 on the rock.
Adjust valves 5 & 6 with 3 & 4 on the rock.
Adjust valves 7 & 8 with 1 & 2 on the rock.
Valve clearance is checked with a cold engine.
Inlet (short rocker arm) 0.2mm.
Exhaust (long rocker arm) 0.3mm.
Alan
  ProfileProfile WebsiteWebsite Send MessageSend Message
SiH
  Reply #2 Posted at Mon Sep 11 10:41:03 2006
Thanks Alan! Thats fantastic stuff. Youve just stopped me trashing my engine.
All the best to you.
Si.
SiH
  Reply #3 Posted at Mon Sep 11 20:07:32 2006
Just adjusted the tappets,and not much different than before to be honest- plumes of black smoke still,either that or somthing else like pump or governor perhaps?
When you say "adjust 1&2 with 7&8 on the rock" ,do you mean adjust 1 when 7`s open,and 2 when 8`s open?
Sorry if I`m being thick!
Member List Member List
Who's online: 17 guests
