question Zetor 25A water pump trouble
reo8rry
sfp13
Hi all, I have a problem with my type 25A, the water pump body is cracked, does any know of a use one that i can purchase so i can get this up and running again
Probably you don't find new waterpump in UK on in rest of world. If you find, let me know, I will make money with them in Finland...
You just must try to fix it.
You can fix it with gasket which you can make yourself. Use prepared sheet of metal to connect other one water pump. 18 mm thickness metal plate with meassured outlets and cone holes for screws. Example: http://www.retrotraktor.pl/artykuly/zetorrozne/pompa.jpg
Thickness 18mm
Size 180 x 150 mm
red line - outline to stick other water pump
blue line - holes original pump
M12 screws to fix this metal gasket to engine with cone nut.
which type of water pump do you mount to this adapter plate ? a UR1 water pump ?
The Ursus C 330 is still made in India. So the supply of C-330 water pumps will last at least another 20 years.
You must contact finland:
http://www.multi.fi/~mcheck/
Here you can find all about Z25
