question Zetor 6245 - hydraulic issue
simon3862
Stratford, Victoria, Australia
Simon
Zetor 6245
Hi there,
Simon from Llowalong, Victoria, Australia here.
My trusty Zetor has developed an issue with the FEL hydraulics. It still lifts with the same power but incredibly slowly.
Any suggestions would be greatly appreciated.
Have you possibly adjusted the reaction speed lever?
The short one at the front of the hydraulic console, which you can swing left and right.
If it moves very easily, the rod under the cabin may have fallen off, then take a look there too.
See also handbook hydraulic instructions section - its explained there.
Thanks for such a quick reply, Joachim. I have been away on holidays and have now had a chance to see if the level was the issue. Unfortunately not....the lever works fine and the rod is still connected. I am wondering if there is a pump failure but not 100% sure where it is located.
Regards,
Simon
The hydraulic pump on your Zetor model is located at the rear under or below the differential. From the outside you will find a circular cover at the bottom, onto which the pump is screwed inside.
Thats what I meant. :)
Check the suction filter which is screwed into the pump plate under the rear axle. No need to drain the oil .
Thanks heaps for your help . I’ve attached a photo of the plate. Is it the suction filter accessed via the bolt in the round housing or is that the drain plug?
No - an external control valve with pressure forwarding was installed on the tractor and the cover of the hydraulic pump was modified accordingly.
Like there:
