102 loader issues
cowheardboy
cowheardboy
Hi everyone hope all is well I have a 6430 with a 102 frontend loader First thing is my loader leaks down only the tilt not the up and down I switched the hydro lines at the couplings where you disconnect the loader so its inverted and it does the something Does anyone have any ideas And second that loader was sitting up for a few years the seals are starting to leak a little bit Does anyone know where I can get cheap rebuild kits in the US Cause the stealership usually want 80 to 100 bucks for one kit
Sounds like leaking piston seals. At a hydraulic shop, or an online shop these kits usually are obtained for 25 euro. That is if you can wait a week for parts. If not, maybe a parts manual describes the type of seal and you can find an equivalent for it of a locally obtainable brand.
Thanks for the info I will try to find some cheap seals and let you know
