135 forterra 2012 engine problem.
forterra9641
forterra11441
Talked to dealer today, and they said they have had to remove the cylinder head of the engine becuase exhaust valves at low temperatures did not go bak and close due to exessive soot on valve stem, leaving the engine with no compression. the solution is to remove the EGR take off the pipe from exhaust to inlet and plug the holes. they have also changed some of the vales due to problems caused by exxessive soot. thats why i hope zetor goes common rail with little or no EGR. id rather have AD blue then engine failiure.
How long have you run the engine at light loads ? Probably driving bales to the cattle with the loader all winter, without ever getting the tractor hot ?
AdBlue is not a magic solution, it also freezes and is heavily corrosive. But its the best of two evils. Manufacturers are given 20 minutes to thaw the AdBlue system before they must comply to the emission standard...
this tactor does almost no light work, in winter its used for snow ploughing etc so thats not the problem, i use my tractors i dont just idle around with it. Exhaust gas has by my opinion nothing to do in the intake side of an engine.
Hmm thats interesting... Ive never heard of that before. I did hear of all kinds of other EGR caused problems (first hand from work) and even stuck valves in just one year ?? What type of oil are you using ? it might improve the problem a bit..
But you're right, from a technical point of view i dont like EGR either, yet manufacturers often just dont have a choice. Retarding injection was a common solution for TIER 2 but caused inefficient combustion and therewith a huge fuel consumption. Then EGR came along, offering the cheapest solution of controlling NoX without the inefficient combustion of injecting when the piston was already on its way down. But to get TIER 3B in the 175-750hp class (2.0gr/kkwh NoX) the amount of EGR is so high that you need a VGT, sometimes two, and a throttle valve to cause an artificial pressure difference between intake and exhaust manifold, the engine is pumping against this pressure (which is energy lost) and there is more flow resistance because a 40% higher volume of air is pressed through the engine. That while adding a lot of complexity.
I am not a fan of italian stuff in common, but the FPT (CNH engine) solution does make for a very straightforward engine. Just commercially available SCR systems offer a reduction of about 80% and FPT developed a system with 95% efficiency, thats why they dont need EGR.
Volvo trucks uses un-cooled EGR, just to increase the exhaust gas temperature at low loads: you want at least 200 degrees into the SCR to let it to function properly.
Anyways, i have no idea whats possible with the current high pressure inline pump, so if you dont need it, no common rail for me. When 20% biodiesel was blended in the mix by law in Holland, both Denso (deere) and Bosch (cummins) common rail systems failed dramatically because of bacteria growth in fuel tanks. Its better now with proper antibacterial additives, but the fact that anything without common rail was just chugging along, proves that the classic pump is better for future alternative fuels..
There are a lot of pros and cons for every path, and the biggest pro for EGR is that you can cap it off afterwards
Yes! no good ever came from an EGR system, i have removed more than i can count on cars and vans and in every case the result was more power and better economy!
it is all too common for the EGR valve to stick, usually half open and half shut, and this will quickly soot up the whole intake system...... oddly enough at all but light loads ...... because light loads is when the EGR is supposed to be open..... not at full power.
Easy to cap it off tho
In NZ we don't need them by law so i just remove the whole system to save weight and space under the hood, but where it is a mandatory fitment then just insert a flat plate (Steel Gasket) between the hot tube and the intake manifold, and you cant even tell it's been disabled
Common rail diesels do give better power and economy....... but i would hate to ever have to pay to fix one out of warranty!!!
Example: Toyota Hilux Ute, 3L Diesel Turbo 4 pot, have used CRDI for the last 7 odd years, almost every one has had to have the Injectors replaced at between 25K and 75K .... to the point that they did a (very quiet) recall and replaced all injectors, pump and fuel lines right back to the tank as a 60K "Special Service"
while this was done under warranty (and without telling the owners) the cost of this repair was NZ$25K ! on a Ute that cost $50-60K New!
i use Castrol power ultra oil so it shouldnt be the oil quality thats the problem.
Blanking off the EGR will solve the problem,Forterra11441 did you sell your other Forterra?
Yep sold it and bought a 6340 instead, since there was nu use in having such a big tractor standing around who with little use, also i wanted a forrestry tractor as vell, and the 6340 came with a full steel belly.
