3011 - controls query
tinman
Tinman
I've recently bought a fairly tidy 3011 with what I understand to be a Zetor loader to use on my smallholding.
I have a couple of questions that I haven't found answers to in the message archives:
1. Is there a way of lifting the seat in order to gain access to the hydraulic connections underneath or do I have to remove the pins from the seat hinge? (My pins are corroded in position and will need a grinder to remove).
2. What exactly do I use the PMS control lever for? I know it's Position; Mixed; & Power - it's fairly unlikely that I'll be doing much ploughing or sub-surface work - mostly I'll be using it for lifting with the loader; rough-cut mowing; hedge trimming; trailer work.
thanks.
PMS setting is just for the 3pt- not for the front loader.
i dont use draft setting for ploughing either: i dont want a consistent workload, i want a consistent working depth
