3045 Linkage.
doctorbig1988
doctorbig1988
Hi all,
The 3 point linkage arms on my 3045 will not lift,I have changed the gearbox oil and filled it to the correct level, the filter behind the seat is clean,the PTO turns and it will tip a trailer but the arms will not work,the Tractor is not uesd often,and has been like this for about 5 years has anybody got any idears,Regards Dave.
You might have a stuck lever inside. i cant tell from here.
Do you want to trade yours for a fully functional 3011 with rebuilt transmission ??
Thanks for the reply,cannot trade this Tractor as I need the 4x4 option,can you tell me if there is anybody on here selling mail order parts for 3045 and 3545 Tractors,I need hydraulic lift piston rings for the 3 point linkage on the 3045, and a price for front axle clutch disks on the 3545, Regards Dave.
We can supply mail order parts for Zetor tractors
www.zetor-dealer.co.uk
Good news,Had the top off the hydraulics today and found two valves stuck in the Hydraulic unit,freed them using a screw driver and some clean oil,put it back together and everything works as it should, Thanks for your Replys Dave.
i have a similar problem with my 3045 hydraulics. The arms lift fine under no load but if you try and pick up an impliment they just wont pick it up.
i noticed some scoring to the hdraulic lift cylinder and piston when i renewed the seals, would this affect it or is it an o-ring somewhere else or maybe even the pump?
any help much appreciated
Chris
Did you replace the 2 small o rings on the removable (2 inch) pipe connecting the pump to the lift head
no i didnt, are there any other o-rings i should replace when i have the hydraulic unit off?
thanks
