3340 won't energize
I
issiah creek
Guest
I have a 3340 and just replaced the hose that runs from clutch to clutch cylinder. I filled the brake fluid resevoir and bleed the system. Now when I place the key in the ignition it won't energize (none of the instrumentation i.e. gas gauge move) and it certainly won't turnover. Hazzard lights and turn lights work. Any thoughts? It was running great until I got a hole in the clutch hose.
Issah,
These two things are totally unrelated!
You do have an electrical problem however. You need to check your electrical connections from battery positive through ignition switch to solenoid to starter.
Does this mean anything to you?
[glow=green,3]TomZ [/]
Yes, thank you. In the mean time from my post I went back and with a tester started checking things out from the starter back. I got to the fuse box and found a slightly loose fuse. As soon as the gauges energized I knew I was okay. Runs great.
