3545 -3 point linkage lever.
doctorbig1988
doctorbig1988
Hi all
The 3 point linkage lever on my 3545 has gone slack,it still works the arms as it should but will not stay in the chosen position,has anyone else had this problem and is it easy to fix,
Regards Dave.
The friction disc tabs have broken off on the pivot shaft in the quadrant, take out cotter pin undo friction adjuster handwheel & change broken parts
Thanks for the info, Doe's anyone still sell these friction disc's and if so how much are they and could I get them mail order,
Regards Dave.
if your looking for zetor parts you can go to www.zetorusa.com
ridge way enterprizes i use them they are great you can get them to send you a parts catalog and they are great if you have any questions very easy to deal with and the ship right away hope this helps you good luck
