3545 Loader,
doctorbig1988
doctorbig1988
My 3545 has a loader with a trip tip bucket, I now want to change
it to hydraulic tip,I have all the parts that I need to do this job - Ram , 2 Spool Valve , hydraulic Pipes, My loader works up and down off the Trailer tipping pipe,Which way do I connect the flow and return pipes from the Spool valve to the Tractor so that I will have a constant flow of oil to the spool valve without using the Trailer tipping pipe,
Regards Dave.
Under the seat by where the trailer tipping pipe is taken off there is another port with a large arrow pointing towards the port connect to here for pressure to your spool valve. For return from your spool valve drill the gearbox oil filler plug & return oil through it. To obtain oil flow push your trailer tipping valve to its lowest position (past the drop position) piping it this way you can still use your trailer tipping valve as normal.
Thanks for the info Alan,I will sort it out early next week,
Regards Dave.
