3545 tyres
zetor3545
matthew morgan
hi i have 11x28 tyres on my 3545 i am having new tyres on the front and am plannong to put the 11x28 on my fergie. i have a pair of 14x28 rims which are like new they need tyres which im willing to put on. how do you think these will look on the 3545:sneaky:
p.s alzet ill ring you next week about a alternator
matthew
14x28 is 16.9x28 in modern measurements. 11x28 is 12.4-28
if you do so you need bigger front tires as well, or they will eat away quick due to excessive friction in 4wd.
whys that if they are 28 tall i shouldnt need to change the front tyre size:sneaky:
It's the metal centre thats 28". Outside tyre diameter ( and therefore its circumference) varies with the width of the centre.
Best solution might be your local tyreman. When he knows your present front/rear sizes he can cross refer to tyre makers ;)listing for lower or higher tyres - this applies to any 4WD tractor. Important thing is that front wheels are not turning too fast or slow for rear ones - fronts are usually advanced 2 to 5%
all this is complicated;) probobaly easier andd cheaper to leave it standard:)
If you put 16.9/14-28, this is 12% bigger circumference then normal.
So, you need to increase fronts for same %.
Fronts are 8.00-20?
If so, new size must be 11.2/10-20 or 8.00-24 then. You'll need wider/taller front rims, and power steering, but tractor will look BIIIG!
