hi i have 11x28 tyres on my 3545 i am having new tyres on the front and am plannong to put the 11x28 on my fergie. i have a pair of 14x28 rims which are like new they need tyres which im willing to put on. how do you think these will look on the 3545
p.s alzet ill ring you next week about a alternator
14x28 is 16.9x28 in modern measurements. 11x28 is 12.4-28
if you do so you need bigger front tires as well, or they will eat away quick due to excessive friction in 4wd.
Best solution might be your local tyreman. When he knows your present front/rear sizes he can cross refer to tyre makers listing for lower or higher tyres - this applies to any 4WD tractor. Important thing is that front wheels are not turning too fast or slow for rear ones - fronts are usually advanced 2 to 5%
If you put 16.9/14-28, this is 12% bigger circumference then normal.
So, you need to increase fronts for same %.
Fronts are 8.00-20?
If so, new size must be 11.2/10-20 or 8.00-24 then. You'll need wider/taller front rims, and power steering, but tractor will look BIIIG!
