4011 clutch
nic
nic
hi, can anyone explain how to correctly use the clutch to engage the pto, what's the little hand lever linked to the pedal? I've managed to rotavate ok but would like to do it with a little less crunching.
Does the PTO stop when you press the clutch pedal all the way down?
It sould stop, and you are pressing the pedal all the way to the flor?
How much free play du you have on the pedal? It might be in need of a adjustment.
I have a service manual PDF on the clutch on my C355 and it is almost the same tractor, send your email address by PM and i can mail it to you.
