4341 alternator not charging along with Tach and hour meter not working
barnie58
Barnie C
Had alternator checked and said it was good. Checked for light on dash not lighting with key on. Light bulb good but swapped with another bulb anyway. Question on exciter which wire on alternator is it and can you manually start it? Tach not working along with hour meter is this possible related to the charging problem? Where is tach sending unit located? Any help would be appreciated!
The instrumentcluster and chargeligt gets it power from the keysvith so that is were i vold started to poke whit my voltmeter. Chek for luse or broken wire`s.
Bjarne
