4341 Super clutch problems
cowsatwork
Vermont, USA
Cal
Zetor 4341 Super, 2x 5211
Have a 2003 4341 Super with 1550 hours on it. We bought it at 600 hours 3 years ago. We are having problems with the clutch. Seems early to have disc or pressure plate problems, since we've put over 5000 hours on our 5211 and are only now seeing signs of wear.
It feels like the clutch disc is slipping -- we have problems starting forward (or backwards) from stop, can rev the engine and have the speed stay the same (or slow down) instead of achieving a higher ground speed. But the slipping is not consistent, so I am puzzled. It slips less first thing in the morning and gets worse as we use it. Sometimes it will slip, engage for a bit, start to slip again, as though the disc is somehow pushing more (and less) into the flywheel and transmitting power. Today, after looking at it in the shop (more on that below), I found that I could bring the tractor to a standstill by pulling up on the PTO clutch handbrake lever, and then make it go again by releasing it.
We have changed both the master and the slave cylinder and bled the things to death. System has good line pressure and no air. However, the pedal still feels a bit spongy, though this is better if the free play is adjusted to minimal and the clutch pedal is set at the highest position off the floorboards.
I've opened both the inspection ports on the lefthand side of the tractor. Found lots of black clutch dust, but otherwise it looks dry, not oily or greasy, no rust or moisture. Turned the clutch assembly around a couple of times and all the fingers appear to be right (3 PTO, 3 engine, set differently.)
So, do I just need to split the tractor for a new clutch, or is there something else I can try through the access port or somewhere else? Thanks for any ideas. By the way, what is it that makes a 'Super' different from others aside from the marketing dept?
As the pto clutch stops the tractor moving it points to the clutch plate being worn out. You could have a look at the gap under the release levers (on the ones with the long bolts), if it's only a couple of mm it's worn out.
You may find the crosshaft is partly siezed. If it had a bad driver in a previous life that probably explains the quick wear issue.
not sure i can help you on your clutch issue but i may be able to provide some insight into the differences in the "super" range of tractor compared to its predecessors. the major differences where an aesthetic/ergonomic overhaul of the cabin and controls. the hydraulic pump was upgraded and the power assisted steering on older models was replaced by a more conventional and hydraulic only steering system acting on a carraro built front axle. automotive style filters were pretty much standard on these machines as well. they are good tractors since they fundamentally still used the "heavy duty" platform of previous models, but some of the plastic components were brittle and faded on the sun, glass doors were prone to break, and electrical gremlins persisted throughout the tractor. a few of these problems were remedied as the "proxima" range were introduced, inluding a heavier clutch. Wish i could help you more with your clutch troubles, but at 1500hrs i would assume it should still be in good order. sounds like something not properly functioning in the unit. if this has been a problem for an extended period of time though, the clutch may have been fried by now.
Mike, is the cross shaft the bit that is turned by the slave cylinder and the clutch handbrake, or something else? The shaft I see seems to function OK -- lots of grease around and easy motion.
im not sure what you mean by cross shaft but the hand clutch should actuate a "shaft" clutch. im assuming this is what your seeing. how is your drive at the PTO? is it also slipping?
not sure how much help its gonna be but im sending you a link to the manual for your tractor:
http://www.cals.cz/zetorservice/files/1/SUPER_Z_3321-7341_GB.pdf
id love to help further but ive never had this series of tractor split before.
Andy
If the design is like the older model tractors (it should be similar) you have a dual acting clutch on a single shaft. the drive clutch pack has a bellvile (conical) spring washer that provides pressure on the clutch plate. these sometimes can crack providing inadequate pressure on the plates resulting in slippage. the PTO clutch is always engaged until released by the hand clutch. Maybe the assembly itself is loose, which may explain why drive is even worse when you pull up the hand clutch. both clutches should be actuated by a lever/cam system which should be actuated by your slave cylinder (the pto is cable actuated i believe). Im taking a guess at your problem but in all reality the only way to find out is by getting your hands dirty and splitting the tractor.
