4718 leaks diesel into engine
agvg
Fordson
Suppose the axle seal is gone on the pump, is this a diesel workshop job or not? We have a well equiped workshop and experience in tractor repairs.
To fit new seals and bearings on the diesel injection pump camshaft im sure the pumping elements need to be removed from the body first as the cam lobes foul the rollers on the bottom of the pumping elements.I brought 2 new cam bearings and 2 new seals for my 3 cylinder FI pump (on my Zetor 3545) as i intended to fit them myself.However i took it to a diesel shop to get the job done as i was not confident in removing and resetting the pumping elements and rack.
