4911 no hydraulics
arthur
Arthur
I looked at a 4911 today, only problem is that the hydraulic remote lever felt loose as in it did nothing, and the three point hitch didn't work. The pump was turning ( I could hear it) and it had oil in the transmission. I had all the levers in the right position. Any idea what could be wrong? And what parts might cost? What would a 4911 be worth In this condition? Engine runs good and gears all work good too. Good tires as well.
I bought the 4911, now is there a port where I can check hyd pump pressure directly off the pump? The hydraulic remote lever feels broken inside and does nothing and the three point hitch does not move. Lever is in correct position and oil level is up to the mark on the dipstick. Or should I take the cover off the top of the diff and see what is happening inside?
Is the pump in gear ?
Yes pump is in gear. I tried in both the first two positions. The pto turns in both positions.
