new owner of zetor 5211 clutch will not disenage .removed inspection plate to check out.clutch finger looks ok buttress cap not broken but just one figer moving.the other 2 figers do not move when you push clutch pedal down, they move only if you pull up on pto clutch handle.is this correct i thought clutch has 3 fingers thanks in advance for your help.
thanks Mike you are right 6 fingers total. tried starting in 5 gear hi range also holding brake on still no luck. buttress caps look ok.tractor has been parked for 7 years when i bought it. engine runs good after injector pump rebuilt. looks like might have to split. thanks for help.
