5211 clutch petal leaking
J
jim
Guest
hi my clutch petal squirts fluid when depressed where do you add fluid it is a 1985 new to me tractor and i dont have a real service manual thanks for any help jim
It sounds like you need a new master cylinder. they are about 70 Euro. Dont get a repair kit, because new ones are of much better quality.
thanks Renze i do need one and a brake one i took it apart today . when i fill the hole under the side cover it comes out the bottom of block i cant figure where to put fluid it seems to be out.
The brake/clutch fluid reservoir is under the bonnet, on the right hand side right before the cab. At least, on our 5245.
i replaced the master cylinder and slave cylinder and cltch is fixed i used it tho pull trees for my pond renovation thanks Renze for the help great forum now for the brake cylinders;)
