5211 lift pump problems
tim_bostwick_
Tim Bostwick
I have tried everything to get the air out of my fuel system. No luck . it runs. Great for awhile then dies. So I bleed the system fires right back up. I've blown thelines back. I've put a new lift pump on. Now I can't get the fuel bowl to fill all the way up. Any info would be great. Thank you.
Fuel bowl is never full, allways some air.
Did you replace the hand primer or the lift pump ?
And all fuel lines?
ive had this on a 7745. it was the pipes in the tank that where faulty and sucked in air. try putting the fuel hoses in a 20 liter can of diesel and see if it runs then. if it does its your tank.
