5245 Hydraulic Lift
breezy
Dale
In order to keep a rotary cutter at a certain height but be able to raise and lower the lift does it need to be (P) position? It does not stay at a fixed height in the (M) position. Where do you check and add hydraulic fluid to the system? Thanks for your help.
P stands for postion. thats the one to use. Oil filler for all the transmission and hydraulics is the plug in the floor near the gearstick. there's a dipstick on the plug
Dave
Thanks Dave, I will check the oil level it may be low because of a leak.
