5245 Hydraulic outlets
wbenchfarms
wbenchfarms
I recently purchased a 5245, on which I have mounted a 594 Allied loader. I'm having an issue hooking up my hydraulics. Standing at the back of the tractor, there are 2 outlets side by side, and then a single below. I am not sure which outlets to hook the in and out on my loader spool valve to, and which direction to put the hydraulic control handle in. Any help would be greatly appreciated.
Your outlets should be numbered 1,2 and 0.
Use 0 (the one on the r/h side) for the return oil . You can use 1 or 2 for the supply depending on which way you operate the lever in the cab. The lever should have 1 and 2 marked on it.
