I have begun the process of replacing the slave cylinders and brake pads on my 1989 5245. The disassembly has been pretty smooth and rather quick. I removed the bolts that hold the gear portal to the brake drum housing. The gear portal has swung down so it is vertical. My problem is that the gear portal housing only slides out approximately 5 mm from the brake drum housing and then stops. Is there a secret to fully remove the portal gear housing from the brake drum housing or do I need to use a little more muscle...???
Kevin
Kevin
