5340 Power Outlet Shaft Clutch Control
colinmcgeachy
Colin
I'm completely new to this and I've just bought a 5340. Spent some time trying to figure out what does what and the "Power Outlet Shaft Clutch Control" light came on. Can someone tell me what that means? Is something broken or did I move something I shouldn't?
Colin
Power Outlet Shaft Clutch Control light, Well power outlet shaft to me sounds like the PTO and when you turn it on there's a light to warn you.
Thanks. I'm pretty sure the PTO isn't spinning but I'll double check. I have the manual but I can't find any other reference to the light other than a graphic of the dashboard and an arrow indicating it's the Power Outlet Shaft Clutch Control.
Have you left the hand clutch lever pulled up.
