5545 3pl wont work
farmerjordan95
Farmerjordan95
Hi everyone I am having trouble getting the 3 point linkage to work on my zetor . It has never worked in the time I have owned it. I have checked the hydraulic pump and I am getting hydraulic pressure to the auxiliary outputs. I also rebuilt the lift ram inside the tractor so thinking that was my problem but it wasn't.
Any ideas what the problem could be?
There should be a lever on top of the back end, just in front of where the hydraulic hoses screw on. Try moving that as it switches the hydraulic pressure between the inner and outer hydraulic circuits. Hope this helps.
ended up finding the problem today seems it had a sticky valve inside the 3 point linkage.
