5718 gear change
richard_a
Richard A
Have a problem with getting gears. When i try to put gear changer into gear it is difficult, gears tearing, could it mean i need to adjust clutch and if so any idea how i should adjust and what setting .I changed a release bearing before so have an idea about setup?
You need about 2.5 cms of free play on the pedal. If this happened suddenly you've probably got a broken buttress cap. (The top hat shaped pieces which the release levers sit on.) You can change them through the l/h side inspection cover.
