5718 Hydraulic fluid leak
richard_a
Richard A
Hi, Have oil leaking out where the three point linkage arms attach to tractor, how do i fix this problem is it a simple job of marking position of arms then removing them and replacing seals ??? My lift arm also drop if i stop tractor so have i a problem with the pump seals ??
Also want to replace the oil in system so how much will it take and am i right in saying i should use 15/w40 tractor oil for the hydraulics ?
