5745 installed clutch, grateing gears
strom
Robert
I cant get the tractor into gear.
I replaced worn out clutch plate, spigot bearing and adjusted the clutch release fingers as specified in workshop manual . I hope the clutch plate is facing the right way. The plate has a half cone shaped mount at its core on one side and a flattish apposing side which is facing back to the flywheel.
The clutch, and PTO thrust bearings are fine. Have taken up any slack in adjustment linkages and left 2ml clearance and 15mm travel for clutch finger and 10mm for PTO, which looked fine under load in the workbench press. I'm stuck and really need your help , come in please?, cheers.
When installing the clutch plate its the side that's got the wider cone that faces the flywheel.
