6011 hydraulics
fluffy57
fluffy
Can I have some help please I have not used the 6011 for 18 months and have forgot what place levers need to be in to operate the loader etc ie the hydraulics .
can someone advise please ,I also will be plugging in a log splitter on the connection at rear
Hi all still 4 months on still no luck with getting pressure to rear plugs so can not use log splitter any more ideas please
Put the hyd handle closes to the seat all the way back and lock it in that position will give hydraulics in the no.1 spool. and have the pto handle fully down turns on the pump.
Thanks for info . I have looked a utube and put lever near seat right back , also got floor lever forward .I have now dont ask me how got lift arm have come up but still no pressure at No 1 outlet .I have filled up with oil !! could with it being low have a air bubble in system ??? . I will have no hair left on my head by end of the week .It has to be something silly as tractor has not been moved for months and all worked before I changed water pump .
To get pressure in no.1 coupling make sure the hyd handle is all the way back and hold it there, the other one works all the way forward. be sure you have plenty of oil in it, or the pumps not air locked.
Thanks for info , I am thinking I have a air lock as lift arms are working so pump is ok !! . But no pressure are services at rear ?? anyone any idea how to bleed it out ?? I have checked oil level and thats ok .
The other thing is the tractor has stood 6 months or more could I have a valve stuck ?? .
Any help would be great PLEASE !!!!
Could be there's something stuck inside ok, but to bleed the hydraulics on a Crystal anyway and I presume yours is the same, is to back the tractor up on a ramp so the back is up high letting the oil run towards the pump and then working the levers back and forward a few times with the engine going, the hyd pipes should jump when engaged.
The pump is in the bell housing in the middle of the tractor on a Crystal but I'm not sure if it's the same on a 6011, but sure you can give it a try.
Someone was saying about a check valve but I have not found anything yet . The funny thing is 2 months ago I had the loader working . The tractor has not moved in that time !! only thing I have done is fit a water pump and change a fitting on the hydraulic return side into rear casting as it was leaking .
So why I have lost pressure to feeds at the rear ??? the lift arms are working and you can hear note of engine change , so got to be something in that poute to rear fittings stopping pressure flow .
Did you check that the pipe is not blocked, or take the loader pipe out of one coupling and into another one. Pull out the pipe and just engage the handle and see if the hydraulics hums
Sorry I may not of explained it very well . I can not get any pressure to the fittings at back of tractor ie services !!! This is why I think may be a valve stuck ?? silly thing is sounds like pump is working and lift arms work . JUST GOING MAD . I am going to try and find a valve in line
Hi All
Thanks for all the advise but still not fixed so on we go .Someone has told me to take filler bung out and put airline on area to try and force fluid through ?? any thoughts please the other is change hydraulic filter as dont think been done for many years ?? How do I change this can anyone help please .
Sorry for keep asking but can not afford dealer prices to get stuff done
THANKS TO ALL
Your filter is on the right side beside the diesel tank, It's got a nut shape on the bottom of the cover and inside there is a paper cartridge to change.
Many thanks again for help with info I have a new filter coming so will try doing that !! and see .
Cheers
