6211 clutch
tyresatocean
tyresatocean
Hi just need some help put in new slave and master cylinders and still wont go into gear was driving ok before the clutch pedal just went to the floor could any one please piont me in the right direction. I should add the pedal feels really light we have bled all the air out of it. Thanks.
The clutch pedal can be light but not soft and you should have some pressure near the end, so if it's not loosing fluid of air, you need to check that anything is happening inside the clutch.
Write your reply...
