6245 Clutch travel release levers
opso
Australia
David
Zetor 6245
Hi all,
Just received parts for my clutch rebuild and the travel release levers (part number 70011105) is not the same as the old ones. There is no hole for the thrust pin and buttress and there is an extra plate welded on.
I'm not sure if I have to remove the Thrust pins and buttresses to make it fit, or I have been sent the wrong parts.
Cheers David
you might have gotten PTO clutch fingers instead of travel clutch.
Thanks Renze and Mike for the reply.
I think you are both correct.
I checked the part numbers on there website and both are the same item.
Do either of you know where I could get the right part.
Regards David
