6245 rear hydraulic problems
kereru
Nick
I recently purchased a new 6245 and the inner and outer hydraulic circuit controls arent able to be moved seperately. So to operate the rear hydraulic ports the impliment must be raised. Any ideas how to fix this?
You push the 3pt lever too far forward. when you push it forward past lower position it starts to lift again.
And did you connect the hose to the right Quick coupler? The free return gets some pressure while operating the 3pt lift
are the levers rusted together at the pivot? wd40 and gentle persuasion with a large screwdriver to get them to move?
0the 2 series does not have this feature renze. only older ones with golden body have this feature. have owned 2 6245 an none had this feature. but the levers can stick togheter due to rust and little use.
