6245 tranny will not stop
chrisloy
part-timer
Hi everybody, I hope someone can help
My uncle has a 6245 4 wheel drive where the transmission will not stop. It was sent to a garge last year and had a new clutch and fingers done and we were told the transmisson preload was not right and the transmission would spin in neutral a little with the clutch depressed.
It was useable until today when all of a sudden even depressing the clutch does not stop you in gear. the oil is up in the resevoir for the clutch cylinder and the cylinder seems to be extending. is there anything else i can check, fix or do something about this
thanks in advance
Chris
