Looked at a 6245 today................has a factory cab, allied loader, 4WD, and very low hours. Ran the unit long enough to see the hour meter working and the rubber is perfect. The loader was run by the units rather slow rear hydraulic outputs and the seller had difficulty changing from the 3 point hitch and the loader (not sure he knew what he was doing). Was taken aback by the numerous bells & whistles, let alone levers and buttons. #1 Any suggestion as to what a pristine 6245 as dscribed might be worth? #2 What would it take to set up an alternate system of a hydraulic pump? New to Zetorworld, hope this isn't to stupid a querey! Thanks
