New guy, I found you through google, great to know you are here.
The clutch pedal on my 1995 6320 goes to the floor, fluid pours out the drain at the bottom of the bell housing. It of course doesn't shift.The brakes still have pressure.
Earlier posts here concerning clutches indicate that the brake and clutch cylinders should stop functioning at the same time as they share a reservoir. Maybe that is not true for this model?
What do you think is the problem? What does anyone here suggest for a solution?
thanks
thanks
