6340 no start
allcarjoe
Joe Julian
Hello I have a 1996 6340 that sat for the winter and will not start,several years ago I installed an electric fuel pump and it has worked well.Im getting fuel to the pump but not injectors. It acts like the fuel is shut off. That fuel lever being mechanical, could it stay shut off in the pump? It has never failed to start before. Thanx for any help
Your question is very similar to another one posted on here only lately.
Zetor 4911 cold start
Started at Sun Apr 8 06:24:34 2018
Hi guys,
I bought a zetor 4911 last year, and it did a fine job throughout the season. I parked it in the barn for the winter, but now when I've tried to start it up to get it ready for spring, it wont start.
The cold start push button doesn't hold itself in when i press it.
The engine runs when i inject "start gas" into the air suction, but stops as soon as i stop injecting.
I've cleaned out the "old diesel" and filled it up with new, and there seems to be no issues with the diesel supply to the engine.
If there's anyone who can point me in the right direction I would be very grateful.
Best regards
David from Denmark
Re: Zetor 4911 cold start
Hi.
Sounds like the rack inn Your injetorpump has sised, take the front cover off the pump and spray som penetraiting oil onn it and try to free it upp vith a skrudriver, you shold see it move vhen you move the trotle and the coldstart augt to pling onn att full trotle.
Bjarne
That was the answer given to the question.
