I need to replace the water pump on my 1995 model 6340 and the process seems fairly straightforward according to my workshop manual. The book assumes the radiator has already been removed, but I was wondering if this is necessary, in order to unbolt the fan. Has anyone managed the job without first removing the rad, and/or the cowl?
There's no need to remove the rad, just disconnect the top hose and push it forward. Put a rag between the steering tank bracket and the rad so you don't damage it. The pumps for the 6340's are pricey. I use one for a 7711 (6201 0615) and change the pulley over, thats the only difference. That is assuming you haven't got the turbo pump with the 3rd outlet.
