6340 won't start
wv6340
Wv6340
My 6340 has been acting up seems to be fuel system. Just quit under normal conditions now won't start hand primer sucks back in when pulled out , does this indicate air in system or what
Got it started with a little starting fluid and bled lines going to injectors died out will idling after 3-5 minutes bled lines again got started died out after moving about 25 yards now no fuel when trying to bleed lines. Does it still sound like blockage or collapsed line between tank and pump or something else?
A common problem is the tube bend coming up from the tank that might be blocked. Loosen the hose at the liftpump an try to blow air and listning if there is a buble sound from the tank. Is the glass bowle filled with diesel or is there a lot of air in the bowle? Also check the banjo at the liftpunp so it is not blocked. How looks the diesel? Have you changed the fuelfilter?
Hazze
Getting ready to go back in field to work and try to get tractor started glass bowl is filled with fuel going to try to blow back through to tank any other ideas to try after if this does not work would be appreciated before I head out thank you
