6341 fuses
markty2
Markty2
Anyone have any idea if the spotlights & headlights are fused on a 2004 6341 super.
I have tried all the fuses behind the dashboard side panel but they are Ok.
Are there fuses hidden somewhere else ?
Mark
the fuses should all be right there. I was into the fuse panel on my 6341 to put more lights on it, I don't think there is any other fuses. does everything else work-flashers, brake lights etc.
I would make sure the switch is okay as they fill up with dust. You can get them apart to clean them. I assume you know that the top lights only work on dip beam and the headlights go off when you turn the top ones on.
Haven't tried cleaning the switch, might give that a go.
All flashers, brake lights, rear spotlamps & headlights are working, but no dips or front spots.
Is there a relay that switches between the front spots & the dips ? Mabye that is the problem ??
Mark
