Bugger!
Is it puffing (just 1 cyl smoking) or continous smoke, all Cyl's effected?
Grumpy, make sure the cold start button housing hasn't worked loose and screwed outward. This is where the max fuel is adjusted, from memory, out is more. It has a locknut that locks against the pump housing. It may have unwound while you where working, but you would notice the button would be in a different position.
Were you working it hard last week? or just putting about?
Could be stuck oil rings....
the old style cast iron oil rings can break or gum up,.... not sure what Zetor used but i would expect 3 piece on a 7 series UR1.
Keep an eye on the oil level, if it is smoking that bad the level will go down over 8hrs use......... if the level goes up..... then it is over fuelling and Diesel is running down the bore past the rings into the sump...... you will also see a slight drop in hot oil pressure as the diesel thins the oil.
if it is "puffing" smoke at idle it could be just 1 CYL effected. test by cracking the injector pipes loose one at a time.
if there is oil coming out the exhaust U vent check if it smells like oil or diesel ...... Rub some between your finger and thumb .... and take a big sniff
also oil will be more slippery than diesel (finger rub test)
It will either get better or worse with hard work
checked! not loose, but can be turned thru 360 degrees and positioned at any angle. I think its supposed to be like that???
I think too little valve clearance is the reason that your pushrod bent in the first place... Then the compression shuts the valve, even though the rocker cant go further.I'm sure a tappet adjust all round will probably help a little further but at least thats one problem solved.
We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
