6911 hydraulic main relief valve
jake99
jake99
I'm looking for the main relief valve,anyone with info/pics where it is located?
Thankx,
Jan
on the mounting plate on which the oil pump is also mounted. its screwed under the bottom side of the differential housing, to access it without tapping all the oil, park it nose down in a deep ditch.
Thanks for the info.
Symptoms with tractor:
Cold the hydraulics worked (not 100% but they worked),after some time (oil temp increase)the hydraulics get slower until the hydraulics stopped with working,the tractor worked like this for some time but now the hydraulics only worked without load en cold oil.
Removed the pump and noticed a cracked pump case due to a failed bearing.
rgds,
Jan
