7045 Fuel problem
H
Henrys Cat
Guest
Help
The tractor runs for a while on tick over then stops through fuel shortage, once pumped up again it starts first time. Runs above idle no problems same with flat out.
We have renewed the filters, and lift pump but still keep getting the same problems.
Need to get it sorted soon as it spends most of the year on the spreader
Back to top
Change ALL your rubber fuel hoses to Gates and this will solve your problem. If you go to the trouble of changing them, make sure that you do change them all[/][/]. A hose that looks alright can close up when working.
Tom
None of the pipes are rubber, they are all plastic. but will try that anyway
