7245 chutch problem Solved
crankshaft
ZetorCan7245
Hello
for two years i had experienced a bad clutch problem I having changed the master and Slave cylinder.
this week i taken away the plate and inspect the clutch mecanis with a flashlight . One of the clutch finger was broken and only 2 finger was in good working condition . I removed the bad finger and welded the crack and add a washer welded on the hole to this bad finger and reassembled .
I have now 3 days operation with no problem .
My tractor has never runing as well than now .
problem solved after 2 years .
now i will arder tree new finger and replace all the finger this summer .
Finger is replacable in one hour .
Langis
