My clutch pedal is nearly at the floor and crunching going into gear. it was fine until slave cylinder bolt came out and piston came out put it all back together and bled it now the clutch is doing this any ideas please.
The clutch and brake use the same fluid from the same reservoir.
Because the suction port of the clutch is higher than the suction port of the brakes, you'll loose the clutch before you loose brakes.
You're simply out of brake fluid.
