7245 issues any advice, is there anyone that can help?
farmerbrooks
Farmer brooks
I was driving my 7245 when it just stopped moving, Now it goes for a couple of feet then stops again. Any clue what this is. The hydrolic fluid has also turned a grey white color. Thanks in advance for your answers,
Randy
not sure if you mean the clutch fluid or the backend oil ???..but sounds like the clutch pack might be knackered ..ie in bits ...does it grind or jump when it moves ?????.....does the pto still work ??..and have you had a look into the bell house to see if its full of bits of clutch plate ..could have ripped the centre cone from the plate ...
