7245 STARTING
robertjohnson
Robert Johnson
I have a 7245, having problems starting, what is 1 & 2 on the key?
whats 1 do? whats 2 do?
is there a cold start?
does it have engine heater?
Many thanks Rob
No engine heater.To start, Open hand throttle, push key in then depress clutch fully and press button. Turning key switches on lights only.
You may find it necessary to pump the fuel up with the hand pump first when starting first thing after the tractor has been stopped for a while, this is a common nuisance with these tractors.
