Recently power steering on 7341 has got slightly heavier,although power steering has not disappeared completely.Any instructions on how to fix this? Thanks.
If the engine is stopped the steering is very heavy due to no pressure and oil-flow from the pump through the orbitrol-valve. Take this fact as an indication to your problem. There could be a internal leakage in the orbitrol however I would firstly check the oil-pump for flow and pressure. If the oil-flow is for any reason to low the steering will feel a bit heavy and a bit slow. The idea to check the filter is not bad.
Any reason for low activity in the forum or is it just the holiday season?
