7745 Clutch stayed in
david_lindsay
David Lindsay
Recently awhile pushing heavy snow my clutch stayed engaged and I cut the fuel to stop. The pedal would not spring back. After I restarted all seemed OK. It was a hard push in 3rd gear for 150 metres and I wonder if I just heated up the clutch momentarily or is there another problem. Thanks
I wouldn't think you heated the clutch : Was there any pressure on the pedal as it went down ? if not , check the fluid level in the small tank under the bonnet near the cab front.The pedal should should be lifted by a spring, similar to the brake ones, if its only being lifted by the master cylinder you ought to get a spring.
Dave
